contact pins in line with the power wire to the a/c relay coil. This is what I did with my Blitz EBC. I connected the unit to switched power but one the oscillating valve wires is is passing by the contact pins of a normally closed relay, powered from the boost solenoid leads. In case of detonation or any other safety boost condition, this configuraion will result in no boost.
